  3. Explicitely selecting dimension of signals
  • Subscribers 132
  • Views 14284
itos
itos over 6 years ago
I have relatively complex expressions in my ADE L many of them result from 2-3 loops. It is very confusing on what dimension of the signal ADE is acting on and for many parts things stop working if I remove one loop.
Example: I have a transient (noise) simulation with multiple runs set to 30. On top of that I may use parametric analysis to sweep 1-2 parameter. I want that the expressions still work when I leave out the parametric sweep (or the multiple runs).
What I want is to calculate the the standarddeviations at time VAR("T0") (this is a variable from ADE L window) over the multiple runs of the noise analysis
  • When I do a parametric analysis on top of it, these standard deviations should be plotted as a function of the swept variables. Without parametric analysis, there is just one result which should be displayed in ADE L.
  • When I do not have multiple runs, then stddev(x) = x, i.e. everything should still work but now there is just no sample set for the calculating the standard deviation
Currently I have a construct like this:
dB20(stddev(((value(v("/vo2" ?result "tran") ymax(VAR("T0"))) / stddev(value(v("/vo2" ?result "tran") ymax(VAR("T0"))))) - (value(v("/vo0" ?result "tran") ymax(VAR("T0"))) / stddev(value(v("/vo0" ?result "tran") ymax(VAR("T0"))))))))
  1. Without the ymax(VAR("T0")), ADE L crashes when there is a parametric analysis. Probably because VAR("T0") is then an array as well. However, without parametric analysis this does not work any more and I would need to manually replace ymax(VAR("T0")) with VAR("T0").
  2. How do I ensure that stddev takes the standard deviation across the multiple runs of the transient noise sim AT the point T0, rather than over the time dimension or even the parameters from the parametric analysis?
