  3. A trapezoidal ringing, but not two point shape, happened...
  • Subscribers 133
  • Views 18240
mangk
mangk over 6 years ago
I have a question about trapezoidal ringing.
During my oscillator simulation, a trapezoidal ringing has been found through spectre.out.
However, when I checked the problematic node reported, the shape of the ringing seems like an ADC output, a quantized analog waveform, not two point shape.
Would it be a right report ?
*** The problematic node is an internal node of a three terminal resistor of ~700 ohm.
(Plus/Minus terminal is connected to GND, and the other terminal a noisy VDD)
*** The peak to peak value of the ringing is around 20 uV.
Any advice would be appreciated.
Sangkwon
    At the very least a picture of what the waveform looks like and exactly what the message is would help.
    Typically tightening the tolerances should reduce trapezoidal ringing (so seeing what you have in the analysis section of your input.scs would help).
