  3. Adding different variable values for different corners from...
  • Replies 12
  • Subscribers 132
  • Views 24831
Adding different variable values for different corners from a file into ADE-XL using SKILL
RFStuff
RFStuff over 6 years ago
Dear All,
I have two variables SWING and VCM as Global Variables in my ADE-XL.
I have another variable FCLK which takes value 17G, 13G. In other words it is swept for each corner with the three values.
I have 2 corners TT and FF in my corner setup.
I have captured the SWING and VCM information in a file as below:-
corner,   FCLK, SWING, VCM
TT,          13G,      1.3,       0.65
TT,          17G,      1.2,       0.60
FF,          13G,      1.4,       0.7
FF,          17G,      1.3,       0.65
Is there way we can make ADE-XL to take the appropriate value for each FCLK  sweep and the corner instead of manually adding the variables ?
I think a SKILL script can do this. But I am not able to make it work for ADE-XL.
Can anybody please tell me how it can be done ?
Kind Regards,
  • RFStuff
    RFStuff over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks a lot.
    It is good enough for my purpose. I would also like to understand this code with command by command so that in future I can modify it for some other need.
    Could you please tell me the documents where I could  find all the commands mentioned in the code and their usage.
    Kind Regards,
    Andrew Beckett over 6 years ago in reply to RFStuff
    Nearly all of the code is core SKILL, with the exception of the axlGetCornerNameForCurrentPointInRun function. The bulk of the code can be understood by reading the SKILL Language User Guide and SKILL Language Reference Manual, with the axl (ADE XL) function being in the Virtuoso Analog Design Environment XL SKILL Reference manual.
    In IC617 and later, you can also use cdsFinder (from the UNIX command line), type in a function or partial function to search, and when you've selected the one you want, the "More Info" button will generally take you to the full documentation for that function.
