  3. Maestro MTS-Option - how to set different reltol for different...
  • Subscribers 133
  • Views 1833
Maestro MTS-Option - how to set different reltol for different subckts?
Sergej Scherer
Sergej Scherer over 6 years ago
I came across a convergence issue and was looking for a possibility in maestro GUI to set reltol for different subckts.
In the MTS-Options of Maestro I could not find it. Therefore, I tried to work around via a Pre-Run Script (which failed), because reltol should somehow be set after netlist creation.
https://community.cadence.com/cadence_blogs_8/b/cic/posts/spectre-tech-tips-spectre-local-options
Where I can find this option in maestro, if it is available there - or how to set reltol for subckts in maestro?
Thank you in advance,
Sergej
    Hi Sergej,
    There's no direct GUI support for this yet. The only way currently is via the Additional Arguments field on the Simulation->Options->Analog form (Misc tab).
