  3. load annotation setup
  • Subscribers 133
  • Views 15370
bid75
bid75 over 6 years ago
I saved the annotation setup using the GUI "Annotation Setup" -> Save.
Sometimes when I try to load the annotationSetup.as file, the file is not visible in the dialog box. I can see the file using unix terminal, but can't load it from GUI.
If it gets loaded, sometimes only some mos have the annotation data - the setup does not take effect of some of them. Then you have to reapply.
Depending upon pdk, vsat_marg is +ve or -ve when the pmos is in strong inversion. Can't rely on it totally.
Rgds
Bhavin
sub-version  IC6.1.7-64b.500.17
    Hi Bhavin,
    Please contact customer support. Trying to debug this via the forums is going to be rather hard, as it would be much easier to see precisely what you've done.
