  3. RF Jitter, parametric sweep in ADE L
  • Subscribers 133
  • Views 14328
wsamples01
wsamples01 over 6 years ago
First post on the Cadence forums here. I'm curious if it is possible to plot RF Jitter as a result of a changing parameter (using the parametric sweep function)
I have the following expression in the "outputs" section of ADE L:
rfJitter(?result "pnoise_sample_pm0" ?unit "Second" ?from 5 ?to 2000000 ?signalLevel "rms")
However when I do a parametric sweep, I get nothing for this output.
Also is there any way to sweep parameter "m", the number of parallelized transistors?
Thanks.
