  3. ADEXL:priority of jobs/runs
  • Views 2217
cato
cato over 6 years ago
If have a couple of spectre simulation runs running in ADEXL.Now I want to get quick results from a new job. How can I priorize it such that it take the next available license without suspending the older runs?
    This is quite hard to answer without knowing precisely how you've set things up. For example, if you have license queueing set up (which is the default - sometimes you might have a different timeout before it gives up though), then any running spectre which is in the queue already will be ahead of any new job. The only solution is to suspend those jobs.
    Probably would be best to discuss this with customer support as then we can talk to you in more detail about your precise configuration.
  • cato
    cato over 6 years ago in reply to Andrew Beckett
    Thanks, Andrew. I use the default setup. Thus I will go on suspending jobs and contact customer support for a better solution.
