  3. ERROR ADE-3036 in momSim
  • Subscribers 133
  • Views 15045
knark
knark over 6 years ago
I am trying to simulate inductance of a wire through Cadence layout editor and Momentum.
After setting up momentum-virtuoso, I tried to run a momentum simulation. I get Error(ADE-3036) which, as I understand, is related to running cadence in 64-bit mode. Normally, It can be fixed  from the ADE L window by going to setup-enviroment-run with 64 bit binary. But, in the case of running a simulation from the momSim instead of ADE L, we do not have that option. So, the question is, if it is possible to enforce run with 64 bit binary in momSim as well. Also, if this error (ADE-3036) can be related to something different in the case of momSim. And if so, how to fix it?
My Cadence version is 6.1.7-64b and Momentum version is 13.00.
Best Regards
Khan
    Hi Khan,
    You should contact Keysight and ask them about this. Momentum (and the interface to Momentum) is developed and supported (and sold) by Keysight and is not a Cadence product. It uses some of the ADE infrastructure, but detailed support questions would be better asked to Keysight (maybe they have a forum where you can ask this, or you could use their customer support).
    Kind Regards,
