  3. IC5141 core dump when launching icfb
  • Subscribers 133
  • Views 15692
rflayout
rflayout over 6 years ago
I get a new core dump each time I launch icfb (IC5141). I'm not sure why and I would like to fix it.
Here is the error message below:
\o Aborted (core dumped)
\o *Error* Failed to launch WaveScan. There is a problem with the DFII
\o installation hierarchy (Exit Code = 214).
\o For further assistance, contact Cadence Customer Support
\o with the diagnostic information available in the log file.
\o You can use AWD as your waveform viewer until the problem
\o is resolved.
\o *Info* Dumping diagnostic information ....
Here are the tool versions:
xterm> icfb -W
sub-version 5.10.41.500.6.150
xterm> spectre -W
sub-version 16.1.0.538.isr11
xterm> assura -W
sub-version 317_USR2_HF7
xterm> qrc -v
Name : qrc - Cadence Extraction QRC - (32-bit)
Description : Parasitic Extractor
Version : 7.1.1-p006
Build Ref. No. : 443565
IR Build No. : 9358
Build Date : Thu Mar 20 01:08:43 PST 2008
Copyright 2005 Cadence Design Systems, Inc.
  • rflayout
    Sorry, forgot Ocean version
    lc-tlva-395{gf925160}586: ocean -W
    lc-tlva-395{gf925160}587: ocean -V
    @(#)$CDS: awd.exe version 5.1.0 08/25/2011 00:31 (cicln04) $
  • RiadKaced
    RiadKaced over 6 years ago
    This means that your Cadence installation is corrupt. You need to reinstall it, make sure you have disk space ...etc. If you are installing through InstallScape then make sure it comes with "sucess" by the end of it.
