  3. Multi Dimensional Plot using parametric analysis
  • Subscribers 133
  • Views 17129
Nader Fathy
Nader Fathy over 6 years ago
I am using parametric analysis of noise simulation with three variables (L, Vdd, Vg) in the simple circuit shown below (L=60nm to 3um, 20pts), (Vdd=0 to 1, 10pts), (Vg=0 to 1, 51pts).
The parametric analysis looped on all variables correctly as shown below, but when I try to plot the thermal noise, the output family of curves are shown for the first value of L=60nm only with all combinations of Vdd and Vg.
Is there any way I can plot all curves with all variations (L, Vdd, & Vg) in Cadence Virtuoso ADE L?
I am using the following versions:
MMSIM Version: 13.1.1.660.isr18
Virtuoso Version: IC6.1.8-64b.500.1
irun Version: 14.10-s039
Spectre Version: 18.1.0.421.isr9
Many thanks in advance!
    Initially I thought this was just a matter of not having scrolled the legend down enough, but I can reproduce it (I decided in the end to not simulate all 10,200 points that you ran; I can reproduce it with 20x5x5=500 runs). It seems something specific to plotting the family of noise contributor results; for ADE L I only get 25 plots (out of 500) and for ADE Explorer I get 75. If I plot the total output noise, I get that for all 500 points in my sweep.
    I'm not sure why (BTW, your graph was confusing because it's plotting the id noise contribution from a pch transistor, but your circuit has an nch transistor - but I guessed the idea nevertheless).
    I filed CCR 2151853 to get this fixed; you would be best to contact customer support and ask for a duplicate to be filed on your behalf so that it can be tracked. I'm hoping it will still be prioritised anyway, but it always helps having a real customer behind it who is facing the issue.
  • Nader Fathy
    Nader Fathy over 6 years ago in reply to Andrew Beckett
    Thank you so much for your help!
    I will file a duplicate DR to track this indeed.
    Kindest Regards,
    Nader Fathy
