  3. How to set DC voltage parameter of "vdc" (analogLib) from...
  • Subscribers 133
  • Views 4957
How to set DC voltage parameter of "vdc" (analogLib) from the voltage generated from another instance?
Meraj
Meraj over 6 years ago
How to set DC voltage parameter of "vdc" (analogLib) from the voltage generated from another instance.
For example, I have a VCVS in a schematic, which gives output X, then I want to set a DC voltage source with the same voltage X.
Thanks and Regards,
Meraj
    You can't. Why would you do this? Isn't that just what a vcvs does?
  • Meraj
    Meraj over 6 years ago in reply to Andrew Beckett
    I have two circuits one finds the desired operating voltage, and other does noise analysis based on the operating point I get from the first circuit
    For the noise analysis I have to use dc source to find the input referred noise, I could not find the input referred noise if I directly use the output from the VCVS. This is why I need to do this.
    Andrew Beckett over 6 years ago in reply to Meraj
    In essence, the input-referred noise is computed using the small-signal transfer function from a source to the output. It computes the output referred noise, and then divides it by the gain from the designated source to the output.
    So you could put a 0-Volt DC source (vdc or vsource) in series with the vcvs output, and use that as the source for the input referred noise. The DC level itself will then be set, and you have the DC source to act as the "small signal" injection point.
