  3. Simulation error with ideal_balun in cadence Virtuoso
  • Views 21358
NorNand
NorNand over 6 years ago
I am using the ideal_balun for the first time to simulate the fully differential amplifier, I found no problem to convert the ground-referenced signal to fully differential signals. But when I put the balun at the output of fully differential signal to convert it to single then I find an error during the simulation and the spectra terminates.
I attached a basic simulation setup with the error message
Thank you for your help in advance
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago
    You seem to be forcing the common-mode voltage both at the input and at the output, with shorts between the input and the output. That's probably not a good idea. Try replacing the common-mode voltage source at the output by an output port.
  • NorNand
    NorNand over 6 years ago in reply to Frank Wiedmann
    Dear Frank
    Your suggestion is working for this circuit as shown in the images below,
    However, in the fully diffe
