  3. ADE Assembler MATLAB Interface and MATLAB Parallel Comp...
  • Subscribers 133
  • Views 15123
ADE Assembler MATLAB Interface and MATLAB Parallel Computing
Nicolas Callens
Nicolas Callens over 6 years ago
For the moment I am using ADE Assembler together with the MATLAB Integration Tools. Though, I wanted to load the results of the simulation in MATLAB in a parallel way. Is this possible?
E.g. I want to do something like this in MATLAB:
parfor dataPoint = 1:amountOfSweeps
       adeInfo.loadResult('test', 'TRANSIENT', 'DataPoint', dataPoint);
end
Or is there another way of quickly loading the results in MATLAB of, for example, 20 sweeps? Because running the code of above takes some time (especially if the amount of sweeps are larger).
Kind regards,
Nicolas
    Hi Nicolas,
    Why you are loading them one data point at a time? If you don't specify the 'DataPoint' it will load across the entire sweep.
