  3. Rod PCELL Inclusion
  • Subscribers 133
  • Views 14961
Rod PCELL Inclusion
PatORiordan
PatORiordan over 6 years ago
Hi Everyone,
I have a very straight forward PCELL created that adds a stretch handle to a simple rectangle, however, I would like to add "boolean inclusion" for the sub-rectangles, in this case 1 inclusion.  I have included my current script below.  Any suggestions or help would be very much appreciated!
Thanks very much,
Patrick
procedure(GGLcreateViaM1M3(cv w l "dnn")
  let((rectRodObj
    ;; create a rectangle on metal1 with x & y dimensions set by w & l
    rectRodObj = rodCreateRect(?name "gglVIA1m1m3"
                               ?cvId cv
                               ?layer list("M1" "exclude")
                               ?width w
                               ?length l
                               ?origin list(0 0)
                               ?subRectArray list(
                                              list(?layer list("M2" "exclude") ?width w ?length l)
    ;; create a stretch handle for the width & length
    rodAssignHandleToParameter(?parameter "w"
                               ?rodObj rectRodObj
                               ?handleName "upperRight"
                               ?stretchDir "X"
                               ?updateIncrement 0.01
                              ) ; rodAssignHandleToParameter
    rodAssignHandleToParameter(?parameter "l"
                               ?rodObj rectRodObj
                               ?stretchDir "Y"
   ) ; let
 ) ; procedure
;; Create the PCell, the "drawing routine" is encapsulated in the
;; GGLcreateViaM1M3 function which does all the work
pcDefinePCell(list(ddGetObj("Sombrero_OT_oriordpj") "new_exclude" "layout")
      (w 10)
      (l 10)
  let(((cv pcCellView)
    GGLcreateViaM1M3(cv w l)
   ) ; let
    I reformatted your code to make it easier to read. However, I then realised that I didn't understand what you meant by:
    Can you explain more clearly? Maybe with a picture?
