  3. How to pass LVS with shorted nets?
  • Views 22098
agrawa64
agrawa64 over 6 years ago
I have a bunch of nets which need to be shorted in my design. I am using the cds_thru to connect the nets in my schematic, and I have shorted those nets in my layout. I am using Calibre to check the LVS, however, it fails giving an error for the shorted nets. How should I fix LVS so that I can generate the extracted netlist?
    It seems to be "let's ask questions about non-Cadence products on Cadence forums week". This is the third similar post this week...
    Calibre is a product from Mentor (a Siemens company) and not a Cadence Design Systems product. So you would be far better off asking this to Mentor customer support.
    • Vote Up -1 Vote Down
  • agrawa64
    agrawa64 over 6 years ago in reply to Andrew Beckett
    Sorry. I will ask at Mentor customer support. Thanks!
  • mustafaali
    mustafaali over 6 years ago
    That problem can be solved using cds_thru instance the LVS view in schematic, and adding a rule for shorting the resistance like this:
    LVS FILTER R(SH) SOURCE SHORT
    However, this will delete one of the shorted  pins  from the extracted view.
    Hope it helps!
    Mustafa.
  • agrawa64
    agrawa64 over 6 years ago in reply to mustafaali
    Thanks, Mustafa. It worked! This was helpful.
