  3. Virtuoso DEF import creates incorrect pathseg widths
  • Subscribers 133
  • Views 15291
Stevemc12
Stevemc12 over 6 years ago
I have a DEF coming from ICC and when I import the wires do not get created at the correct widths. For instance, the DEF specifies
UNITS DISTANCE MICRONS 4000 ;
   + LAYER m2 WIDTH 104 SPACING 80
But when my design is imported all m2 paths are width 0.025um instead of 0.026um. Is this due to an override in my techfile or something? I have similar issues in other metal layers as well, and it seems to be affecting all wires.
for technical info:
# IC Compiler II write_def
# Release : P-2019.03-SP2
VERSION 5.8 ;
Virtuoso version ICADVM18.1-64b.500.4
    I think we'll need to see the DEF and the technology file for the specific case to understand what is going on here (there are too many variables otherwise that might mean that what I could test don't match what you have) - so customer support is your best avenue for that.
