  3. Plotting transistor operating point components in DC si...
  • Views 24605
Plotting transistor operating point components in DC simulation
NorNand
NorNand over 6 years ago
I am using Cadence Virtuoso IC6.1.5-64 bit and ADE Spectre Version 11.1 2012
I am trying to plot different operating point components of the MOS transistor (gm, region, vth,...etc). In my simple simulation test, I am connecting one NMOS transistor with a fixed VDS and sweeping the VGS. I need to record the drain current gm and region.
For the current I could plot it by choosing the output from the schematic and then probe the drain point terminal, no problem of simulating it.
To plot the gm and region , from the output setup in the ADE I select open calculator, in calculator I tick the op (represent the operating point), then it shows me to touch the concerned instance, after that the op list will be updated and I can choose from the list the parameter I want then tell him to get the expression. Now I have all the interesting components in my ADE output.
The problem when I do the DC sweep of VGS the simulator only plot for me the drain current, while the other values I selected for my operating point are not drawn rather the simulator gives me only one value as a number in the ADE output table.
To get a plot I do a trick by sweeping the VGS from parametric analyses (not by sweeping DC value from DC simulation setup in ADE) but this takes considerable large time, the result then comes as shown below.
My question how to get the plot from DC sweep rather than from parametric analyses
Thank you for your help
  • NorNand
    I recently found a solution of this problem suggested by one friend. I create a text file with the extenstion (saveop.scs) and I write inside it save * sigtype=all
    I need next to add this file in my ADE stimulus file and run the simulation. All the transistors parameter will be saved and I need to explore it from result explorer.
    Perhaps Cadence they have a better solution, but this is the one I have right now in my hand
    Thank you
    Andrew Beckett over 6 years ago in reply to NorNand
    Yes, this has been answered many, many times on these forums - either using the older include file approach, or if you weren't using a 7-8 year version of the tools, it's available under Outputs->To be Saved->Select OP Parameters (this was added in an IC616 hotfix release; we're now on IC618).
    So yes, we have a better solution - you're missing out by using such old software.
  • NorNand
    NorNand over 6 years ago in reply to Andrew Beckett
    Thank you very much Andrew,
    Hope our department upgrade to the new version, any way this problem is being solved
