  3. Import .mod file
  • Views 15800
Import .mod file
nicola91it
nicola91it over 6 years ago
Hi all,
I am using IC6.1.8 version and trying to import the spice model of an external component; in the netlist there are only capacitors, inductors and resistors. I already did It in the past, but It seems that this time I cannot make things work. What I do is file->import->spice, and in the input section I specify:
Netlist file: name of my file .mod
Netlist language: SPICE
Reference lib: analogLib (I only have passive components)
In the output section I just specify the out library, and in the device map I specify:
Device to map: capacitor, mapped to: cap
Device to map: inductor, mapped to: ind
Device to map: resistor, mapped to: res
When I run It, it says that "capacitor" symbol was not found in analogLib, while I expect it to look for "cap" instead. Moreover, no matter how I change the device mapping section, even if I remove "capacitor" at all, the Spice In log keeps giving the same error.
Any idea?
Nicola
P.S. my .mod looks like
.SUBCKT comp_name port1 porte
C01 port1 N01 value1
R01 port1 N01 value2
and so on...
