  3. AHDL read-in errors
  • Views 15431
AHDL read-in errors
pietrobu
pietrobu over 6 years ago
the simulation with Spectre of a netlist with many proprietary VerilogA model is failing due to the following errors:
Error found by spectre during AHDL read-in.
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. ...
ERROR (SFE-91): Cannot run the simulation because an AHDL compilation error occurred. ....
Error found by spectre during hierarchy flattening.
ERROR (SFE-46): .... can have at most 0 terminals (but has 4).
The same netlist was running without errors on a previous version of Spectre. Could you please help me solving this issue?
Thank you,
Pietro
