  3. Inherited Parameters in Callbacks
  • Subscribers 133
  • Views 5864
Serjik
Serjik over 6 years ago
How can i use it ?
The manual says:
Do not use callbacks based on parameters whose values are defined by expressions that include inherited parameter functions.
But if i need it, how should i make it ?
1. I have cell A which consists of 20 resistors. Cell A has 20 parameters which can be either 0 or 1. Depending on the value of the parameter I want to change the value of the resistor.
2. How can i translate parameters through the hierarchy ?
    You can't. This is not possible in general (even if you wanted it to be possible) for the reasons I outline in The Dangers of CDF Callbacks. There may be some specific cases where the hierarchical path is guaranteed to be unique where in theory you might be able to do this, but you don't know in advance if this is the only use ever of that particular hierarchical set of parameters that might exist.
