  3. Finding the minimum voltage from a bus of signals
  • Views 14795
eyalg
eyalg over 6 years ago
Hi all,
Is there a way to find using expression the signal with the minimum voltage out of few signals in bus?
For example:
this expression will give set of 11 values :  value(VT("/vout<10:0>") 3e-10)
And I want to write an expression that will give the minimum value out of the 11 values.
  • mschw
    mschw over 6 years ago
    you could use: ymin(value(VT("/vout<10:0>") 3e-10))
    Kind regards,
    Matthias
