  3. Config view does not switch schematic and calibre views
  • Views 17896
rotorres
rotorres over 6 years ago
Hi all,
I successfully extracted the calibre view of my circuit and now I am creating the config view to perform post-layout simulations.
I created the config view using the spectre template and it generates the view list and the stop list required to simulate. However, when I change the type of view between schematic and calibre the simulation results obtained using ADEXL are the same. I probed adding "calibre" to the view list in the config but it did not work.
I am sure that my calibre is correctly extracted because when I simulate the calibre view using ADEL and changing the environment and adding calibre, the simulation result is different than schematic.
Does somebody have any idea about this problem?
Thanks in advance,
Rolando
  • rotorres
    I solved the problem.
    It was due to a change in the design selected in the ADEXL. Once the Config is created is necessary to go to the ADEXL, make a right-click in the test, select the design and choose the change the schematic option for config.
