  3. virtuoso command show running response
  • Views 25665
mayyola
mayyola over 6 years ago
i use Centos 7 x86_64
[root@soc02 ~]#cat /etc/redhat-release
CentOS Linux release 7.7.1908 (Core)
[root@soc02 ~]# source /cad/cadence/CIC/ic.cshrc
[root@soc02 ~]# virtuoso
WARNING: HOST <soc02> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
For More Info, Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
*ERROR* Display ":10.0" doesn't support 24-bit, 16-bit, or 15-bit true color needed to run this application. Please reconfigure Xserver with an appropriate visual.
[root@soc02 ~]#/usr/cad/cadence/IC/IC_06.17.709/tools.lnx86/bin/checkSysConf IC6.1.7
the log follow below,the 64bit package is ok is need install 32bit package ? because 32bit package looks like fail from log ?
or have any way to fix it  thx.
WARNING: CheckSysConf detected your system is CentOS. This is not supported.
Only the following OS versions are supported by Cadence:
www.cadence.com/.../cadence-platform-support-plan.pdf
We will perform system verifications, but there is no guarantee Cadence software will run on this system.
[Copyright 2002-2016] Cadence Design Systems, Inc. All rights reserved.
This program and online documentation may not be copied, modified,
re-published, uploaded, executed, or distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf: Version 3.25 ====================
Operating System release details:
Date information gathered: 銝€ 11??11 09:41:18 CST 2019
Host Name ..............: soc02
Hostid .................: 758ca2a6
Operating System .......: Linux / x86_64
OS Version .............: CentOS Linux release 7.7.1908 (Core)
Kernel Version .........: 3.10.0-1062.4.1.el7.x86_64
Hardware Type ..........: x86_64
Memory .................: 15302 Megabyte
CPU model ..............: Intel(R) Xeon(R) Silver 4110 CPU @ 2.10GHz
No. of CPUs ............: 32
Total Swap Space........: 5119 Megabyte
X Server ...............:
Patch Data file ........: /usr/cad/cadence/IC/IC_06.17.709/share/patchData/Linux/x86_64/redhat/7.0WS/IC6.1.7
**************** Now verifying configuration ****************
Validating Kernel requirements...
Minimum Installed Status Info
3.10.0-123.8.1 3.10.0-1062.4.1.el7.x86_64 PASS
Validating MEMORY requirements MegaByte ...
2048MB 15302MB PASS
Validating SWAP requirements in MegaByte ...
4096MB 5119MB PASS
Validating DISPLAY requirements...
8 planes PASS
PseudoColor TrueColor
Validating PACKAGE requirements.....23 to check
# PACKAGE Release Build Installed Arch Status Info
1 glibc 2.17 55.el7_0.1 2.17-292.el7 i686 PASS
-> 'GlibC'
2 glibc 2.17 55.el7_0.1 2.17-292.el7 x86_64 PASS
-> 'GlibC'
3 elfutils-libelf 0.158 3 - FAIL Package not installed.
-> 'Libelf Library'
4 elfutils-libelf 0.158 3 0.176-2.el7 x86_64 PASS
-> 'Libelf Library'
5 ksh 20120801 19 20120801-139.el7 x86_64 PASS
-> 'ksh'
6 redhat-lsb 4.1 27 - FAIL Package not installed.
-> 'lsb'
7 redhat-lsb 4.1 27 4.1-27.el7.centos.1 x86_64 PASS
-> 'lsb'
8 mesa-libGL 9.2.5 5.20131218 - FAIL Package not installed.
-> 'Mesa libGL Library'
9 mesa-libGL 9.2.5 5.20131218 18.3.4-5.el7 x86_64 PASS
10 mesa-libGLU 9.0.0 4 - FAIL Package not installed.
-> 'Mesa libGLU Library'
11 mesa-libGLU 9.0.0 4 9.0.0-4.el7 x86_64 PASS
12 motif 2.3.4 7 - FAIL Package not installed.
-> 'openmotif'
13 motif 2.3.4 7 2.3.4-14.el7_5 x86_64 PASS
-> 'openmotif'
14 libXp 1.0.2 2.1 - FAIL Package not installed.
-> 'libXp'
15 libXp 1.0.2 2.1 1.0.2-2.1.el7 x86_64 PASS
-> 'libXp'
16 libpng 1.5.13 5 - FAIL Package not installed.
-> 'libpng'
17 libpng 1.5.13 5 1.5.13-7.el7_2 x86_64 PASS
-> 'libpng'
18 libjpeg-turbo 1.2.90 5 - FAIL Package not installed.
-> 'libjpeg'
19 libjpeg-turbo 1.2.90 5 1.2.90-8.el7 x86_64 PASS
-> 'libjpeg'
20 expat 2.1.0 8 - FAIL Package not installed.
-> 'libexpat.so.0'
21 expat 2.1.0 8 2.1.0-10.el7_3 x86_64 PASS
-> 'libexpat.so.0'
22 glibc-devel 2.17 55.el7_0.1 - FAIL Package not installed.
-> 'GlibC-devel'
23 glibc-devel 2.17 55.el7_0.1 2.17-292.el7 x86_64 PASS
-> 'GlibC-devel'
Validating FILE existence .....0 to check
Validating NOTFILE existence .....0 to check
Configuration checks failed on this workstation (soc02), status is: FAIL
WARNING: CentOS is not supported by Cadence software. The software might not work correctly
even if no other errors are found. For the list of supported OS versions visit:
This system does not have the correct packages to run IC6.1.7
Run checkSysConf IC6.1.7 -P <PACKAGE>
to find out which products require this package.
Exiting checkSysConf ... Good-bye
Output is saved as /tmp/checkSysConf.soc02-2019.11.11.09:41.15349.log
  • mayyola
    I install i686 package but virtuoso still wrong
    [root@soc02 ~]# virtuoso WARNING: HOST <soc02> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.  For More Info, Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
    *WARNING* X Window Display Initialization failure *WARNING* (DISPLAY "<not defined>")
    and log
    Date information gathered: 銝€  11??11 10:25:50 CST 2019
    Patch Data file ........:  /usr/cad/cadence/IC/cur/share/patchData/Linux/x86_64/redhat/7.0WS/IC6.1.7
                2048MB    15302MB   PASS
                4096MB    5119MB    PASS
              ---               ---               FAIL    DISPLAY couldn't be opened. Set DISPLAY variable correctly
    ->  'GlibC'
    ->  'GlibC'
    3   elfutils-libelf        0.158      3              0.176-2.el7             i686        PASS
    ->  'Libelf Library'
    ->  'Libelf Library'
    ->  'ksh'
    6   redhat-lsb             4.1        27             4.1-27.el7.centos.1     i686        PASS
    ->  'lsb'
    ->  'lsb'
    8   mesa-libGL             9.2.5      5.20131218     18.3.4-5.el7            i686        PASS
    10  mesa-libGLU            9.0.0      4              9.0.0-4.el7             i686        PASS
    12  motif                  2.3.4      7              2.3.4-14.el7_5          i686        PASS
    ->  'openmotif'
    ->  'openmotif'
    14  libXp                  1.0.2      2.1            1.0.2-2.1.el7           i686        PASS
    ->  'libXp'
    ->  'libXp'
    16  libpng                 1.5.13     5              1.5.13-7.el7_2          i686        PASS
    ->  'libpng'
    ->  'libpng'
    18  libjpeg-turbo          1.2.90     5              1.2.90-8.el7            i686        PASS
    ->  'libjpeg'
    ->  'libjpeg'
    20  expat                  2.1.0      8              2.1.0-10.el7_3          i686        PASS
    ->  'libexpat.so.0'
    ->  'libexpat.so.0'
    22  glibc-devel            2.17       55.el7_0.1     2.17-292.el7            i686        PASS
    ->  'GlibC-devel'
    ->  'GlibC-devel'
    Unable to open DISPLAY. Configure your DISPLAY variable correctly.
    Output is saved as /tmp/checkSysConf.soc02-2019.11.11.10:25.28206.log
    Andrew Beckett over 6 years ago in reply to mayyola
    What is the UNIX environment variable $DISPLAY set to?
    Can you run (at the UNIX terminal) "xterm &" and see whether a terminal launches? it sounds as if your X environment is not set up properly.
    What are you using for display - are you directly on the Linux machine or are you using something like VNC, Exceed, NoMachine NX or something like that to display the graphics?
  • mayyola
    mayyola over 6 years ago in reply to Andrew Beckett
    i use xrdp(win10 remote) revise the display color to choice 24bits is worked now and MobaXterm is ok
    but now i face the another problem..i choice file =>new=>library  the new library list  is  garbled  ,is it correct ?
    the link of picture follow below
    https://imgur.com/hqkp8T4
    thx
    Sounds like the fonts are not set up correctly on your X server.
