  3. How to set a custom via as default via on VXL/GXL?
  • Views 1615
Tom Sawyer
Tom Sawyer over 6 years ago
Hi Cadence Support
Is there a way to set a custom via as the default via?
What I am currently doing:
1. On vxl invoke 'Create via"
2. Choose via definition
3. Adjust rows, columns & cut size spacing to desired value.
4. Save then repeat doing this on each layout view.
Is there a built in feature on vxl to do this faster?
Do I need to load some skill files?
  • Vallabhamj
    Vallabhamj over 6 years ago
    Hi Perry,
    One way to do is to save all the options into "~/.cdsenv" file. So you don't have to repeat the above steps every time when you open a new layout.
    To save options into .cdsenv file.
    Go to CIW -> Options -> Save defaults -> OK.
    When you open a new layout, your customizations are directly loaded from "~/.cdsenv" file.
    Thanks & Regards
    Vallabha
