  3. How to save subckt parameters in Spectre
  • Views 16175
Dessai
Dessai over 6 years ago
I have device model in subckt form with instance parameter "w".
This model has another parameter "r" which is a function of "w".
How to save subckt parameter "r" as I sweep parameter "w" in Spectre.
    I'm not sure this is possible - you should contact customer support for an enhancement request.
    If the underlying device has a suitable parameter you may be able to do it another way - for example:
    inline subckt forumres (p n)
    parameters w=1u l=10u r=l/w*0.1
    forumres (p n) resistor r=r
    ends forumres
    I1 (n1 0) isource dc=100u
    R1 (n1 0) forumres w=2u
    save R1:res
    save n1
    dc dc dev=R1 param=w start=0.2u stop=2u step=0.2u
  • Dessai
    Dessai over 6 years ago in reply to Andrew Beckett
    Thanks for your help.
