  3. How do I send Stability Summary into the Calculator?
  • Views 17749
Nader Fathy
Nader Fathy over 6 years ago
I have an iprobe in a loop of a feedback amplifier, and I am running PSS with PSTB simulation. When simulation finishes, I click on ADE L results >> Analysis "pstb" >> Function "Stability Summary", and this shows me the Phase Margin and Gain Margin summary.
How do I load these results into a calculator to send them to ADE? I need this because I want to run Monte Carlo on my amplifier to check that it will be stable with process/mismatches.
I am using the following versions:
MMSIM Version: 13.1.1.660.isr18
Virtuoso Version: IC6.1.8-64b.500.1
irun Version: 14.10-s039
Spectre Version: 18.1.0.421.isr9
Many thanks in advance!
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago
    There are at least two possibilities for adding results to the outputs. One is the "Add To Outputs" option of the Direct Plot form and another one is the Right-Mouse-Button Menu of the Results Browser.
  • Nader Fathy
    Nader Fathy over 6 years ago in reply to Frank Wiedmann
    Thank you Frank!
    The "Add To Outputs" is not available in "Stability Summary" window, but I was able to search for it in the Results Browser and sent it to ADE L successfully.
    Again, many thanks for your help.
    Andrew Beckett over 6 years ago in reply to Nader Fathy
    You're quite right. This is a limitation we should fix. I found an old request which was voided because part of it was implemented, but the direct plot phase/gain margin and PM/GM frequency entries (with "add to outputs") were not implemented. The new request is CCR 2186596.
