  3. Hspice replacement for Switch from AnalogLib
  • Views 18769
circuitmonkey
circuitmonkey over 6 years ago
Hello ,
I was using switch component from AnalogLib  in Spectre  (open voltage=0, closed voltage =1 , Open Switch Resistance=1G and Close switch resistance = 1) and I have recently developing a test circuit in Hspice .  Is there any component or subcircuit /macro model in hspice  which can replace switch I used in spectre . I tried VCRES but it does not seems to work.
Any help will be really appreciated .
    There is no analogLib equivalent of switch (which is a relay in spectre) for the hspiceD interface. The best option would appear to be the vcres component - what doesn't work about it? How have you got it configured?
  • circuitmonkey
    circuitmonkey over 6 years ago in reply to Andrew Beckett
    Thanks for quick reply.
    I tried using VCRES to make equivalent to switch. I used following setup
    Volt/res conversion factor = 100M
    Max output resistance =10G
    Minimum output resistance =0
    Rest of parameters were left  blank.
    My control voltage is changing from 0 to 1V
    Andrew Beckett over 6 years ago in reply to circuitmonkey
    What does the resulting netlist look like (the line for this vcres component)? I probably can't test it with HSPICE (you may need to ask Synopsys instead of asking here), but at least I can check whether the netlist line looks reasonable...
