  3. ADE Assembler - Changing the Maximum Jobs while a Run is...
  • Views 2524
ADE Assembler - Changing the Maximum Jobs while a Run is In Progress
Tjaart
Tjaart over 6 years ago
I am using ADE Assembler in IC617.
I was wondering if there is a way to change the Maximum Jobs entry in the Job Policy Setup form, during an active run?
I tried updating the parameter during the run, but only when I stop and restart it do the changes come into effect.
I would like to manually manage the Maximum Jobs during a run as resources come and go.
I am using a local distribution method.
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago
    This has always worked for me (at least in ADEXL). Did you select the "Start Immediately" checkbox?
  • Tjaart
    Tjaart over 6 years ago in reply to Frank Wiedmann
    Thanks for your input Frank. Yes I also remember it working on ADEXL.
    I just retried by presetting the "Start Immediately" checkbox to both values before re-running, but this did not resolve the issue.
    I had a look at the description of the "Start Immediately" setting in the ADE Assember user manual, but its function is not very clear to me.
    Andrew Beckett over 6 years ago in reply to Tjaart
    I would contact customer support - unless I've misunderstood what you're saying, this should work, as Frank said.
