  3. Spectre assert output message - printing a variable
  • Views 2653
Shico90
Shico90 over 6 years ago
Is it possible in spectre assert statement to print in the warning message a parameter or a variable?
For exmaple something like this
pmos_vgs assert mod=pch expr="(abs(V(g,s))>1.3)" message="Maximum gate source voltage exceeded the limit %d",abs(V(g,s))) duration=0.1n
I know the message doesn't work but is there something like this?
Sherif
    Hi Sherif,
    Don't write the expression as a condition. Instead do this:
    pmos_vgs assert mod=pch expr="abs(V(g,s))" max=1.3 message="Maximum gate source voltage exceeded the limit" duration=0.1n
    It will then show the value of the expression when it violated the min/max. Note, I didn't test this, but something along these lines should work.
  • Shico90
    Shico90 over 6 years ago in reply to Andrew Beckett
    Thanks a lot Andew !!
    Sherif
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago in reply to Shico90
    You also might want to take a look at https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20370332 and https://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=20402385.
