  3. Cannot EDIF out
  • Views 16182
Cannot EDIF out
Kevinholo
Kevinholo over 6 years ago
        I tried to edif out an inv schematic in library test which contains all devices in inv.
        But edifout.log shows "Error : Failed to open library test -- exiting". However, I succeeded edif out from library analogLib.
        What is the difference between test defined by me with analogLib? How can I edifout successfully?
        Thanks.
  • Kevinholo
    I copied analogLib to a new library analogLib_test, and did the same edifout process but failed. Comes out the same error message "Error : Failed to open library test -- exiting"
    Andrew Beckett over 6 years ago in reply to Kevinholo
    Please contact customer support - it’s going to be very hard to debug this without seeing your data and setup. Unfortunately the error messages given by the EDIF interface are not very detailed so seeing what you’re doing would be a real help.
  • yankunRen
    yankunRen over 6 years ago in reply to Kevinholo
    I encountered the same problem and I don't know how to solve it
