  3. malias function
  • Views 16641
malias function
VINCENTCHENG
VINCENTCHENG over 6 years ago
Does ADEXL has the "malias" function as in HSPICE?
Ex:
.malias nch = nch_mvt
(I want to change all 'nch_mvt' in the schematic to 'nch' without modify schematic )
thanks.
    Your question doesn't really make sense. ADE XL is not a simulator. Spectre (which is a simulator) does support model aliasing, and you can do that either with the SPICE syntax:
    .malias nch=nch_mvt
    or with the spectre syntax:
    model nch_mvt nch
    Are you using spectre as the simulator? Maybe that's what you want - to tell the simulator to alias the model?
  • VINCENTCHENG
    VINCENTCHENG over 6 years ago in reply to Andrew Beckett
    I use Spectre as simulator.
    I want to know where to set  "spectre syntax: model nch_mvt nch" in ADE XL.
    For HSPICE, I just simply put ".malias nch=nch_mvt" in my .sp file.
    Andrew Beckett over 6 years ago in reply to VINCENTCHENG
    Create a file called (say) alias.scs and put:
    model nch_mvt nch
    in that file. Then add this file via Setup->Model Libraries in ADE (for the test) or Setup->Simulation Files under Definition Files.
    Or you could create a file called alias.sp and put:
    .malias nch=nch_mvt
    and then reference that file in the same way. If the suffix is ".scs" then it's assumed to be in Spectre syntax; otherwise it's assumed to be in SPICE syntax.
