  3. Set Subwindow ID for each Trace / Waveform
  • Views 15158
ChristophIMS
ChristophIMS over 6 years ago
I am working with IC 6.1.8. After a transient simulation in ADE Explorer, where I have defined several outputs (signals and expressions), all signal-waveforms are plotted in the same subwindow and all defined expressions are plotted each in a separate subwindow (although they are based on the same x-value range / time range). I would like to know if there is any possibility to define the subwindow a waveform (expression / signal) is plotted to?
It would be ok if its only possible for expressions (e.g. in the following way: "subwindow(v("/X1" "?result" "tran") 1)" for plotting the waveform in subwindow 1)...
Many thanks and best regards,
Christoph
    In IC6.1.8 with Explorer and Assembler, you can plot the graphs automatically, and then rearrange as you prefer into different sub windows. Then in ADE in the Results tab click on this icon:
    Give the template a name. Then you can pick to plot in "Replace" or "New Window" with the named template (that's in the cyclic choice next to the highlighted icon in the screen grab above).
    This is covered in this blog: Virtuosity: Maestro Plotting Templates
    If  you've not already done so, I'd recommend subscribing to the blogs as then you'll get notified when we post new content on the blogs (there's a subscribe button on the left hand side).
