  3. Dump a Verilog Code in Cadence Virtuso.
  • Views 15922
JAYDIP BISWAS
JAYDIP BISWAS over 6 years ago
I have a verilog code. I want to dump the code in Cadence Virtuoso and use the instance in my design. what is the procedure for it?
    I moved this to a more appropriate forum (the Feedback, Questions and Suggestions forum is for issues with the forum itself and not for technical questions).
    If you have some Verilog code, you could use File->Import Verilog, which will then import the code and offer to create symbols for you. Have you tried that?
  • JAYDIP BISWAS
    JAYDIP BISWAS over 6 years ago in reply to Andrew Beckett
    Yes I have done that. But I dont know the proper process because I am new in Virtuoso. If possible send me the detail process how to create. thank you.
    Andrew Beckett over 6 years ago in reply to JAYDIP BISWAS
    Rather hard to know what exactly didn't work (or even if it did work) because you gave so little information. You could also read the documentation (hit the Help button on the File->Import->Verilog form). I suggest you contact customer support.
  • JAYDIP BISWAS
    ok. Thank you.
