  3. Verilog $random seems to be not random
  • Views 20707
HoWei
HoWei over 6 years ago
I want to generate a random number between -1 and 1 in Verilog-A by using "$rdist_uniform" or "$random", but the behaviour is not as I expect it.
My code is something like:
@ ( initial_step ) begin
for (1=0; i<10; i=i+1) begin
   myvar[i]= $rdist_uniform(seed,-1,1)
end
end
When "seed=123" ( a constant) i always get the same value in myvar[0:9].
When "seed=i" the values in myvar[0:9] are increasing linearily.
I am missing the "randomicity" in the values.
If I would need to scramble the seed, I also could use the scrambled value instead of the random function.
How can I generate randomly distributed values ?
  • HoWei
    Okay, I found that (for whatever reason) it works when I place the seed variable outside of the for loop:
    seed=32134
    end
    end
    Andrew Beckett over 6 years ago in reply to HoWei
    You shouldn't give a new seed every time you call it as that would give a very non-random sequence. The original sequence was indeed random, but it's just that you're starting from a fixed seed (which is usually a good idea for reproducibility of results; it would be very annoying if each time you ran the simulation you got a different answer, as otherwise you couldn't reproduce a previous observation).
