  3. AMS simulation error after removing a verilogA cell from...
  • Views 15655
AMS simulation error after removing a verilogA cell from the testbench
RFStuff
RFStuff over 6 years ago
Dear All,
I was running a testbench in ADE with AMS engine. It had vHDL and verilogA modules. It was running fine.
But when I removed the verilogA module (i.e. DCO present in VERILOG_A_MODULE_2 library) it shows the following error and simulation doesn't run.
ncvlog: *E,WKLNDF (./INCA_libs/AMSD/ahdl_in/generated_skeleton_ahdl.skl_vams,191|27): library 'VERILOG_A_MODEL_2' is not defined.
module worklib.DCO:veriloga
errors: 0, warnings: 0
Total errors/warnings found outside modules and primitives:
errors: 1, warnings: 5.
Can anybody please tell how to fix this issue.
Kind Regards,
    I've not found any records of that error reporting issues with generated_skeleton_ahdl messages. I think this would be much easier to debug via customer support, as otherwise there would need to be quite a bit of guess work.
    Is this module instantiated in a hierarchical VerilogA module? Which INCISIVE subversion are you using (what does "irun -version" give in the terminal window)? Are you using UNL (Unified Netlister) on the Simulation->Netlist and Run options form? Have you tried checking the "Clean snapshot and pad files" on that form?
  • RFStuff
    RFStuff over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    My Netlist and Run option form is as below:-
  • RFStuff
    RFStuff over 6 years ago in reply to RFStuff
    With "Clean snapshot and pak files", it indeed works.
