  3. Missing point in AMS simulation plot when the value of the...
  • Views 14832
Missing point in AMS simulation plot when the value of the consecutive points are same
RFStuff
RFStuff over 6 years ago
Dear All,
I was simulating a VHDL module in AMS with plot in VIVa.
The module looks like as at the end of this post.
If deltat_rec value is same at nth, n+1th rising edge of clock signal 'clk', the wavescan plot  ( in SampleHold  trace format ) of signal deltat_rec does have a point at nth rsing edge but NOT at  n+1th rising edge.
Is there any we can ensure that the WaveScan plot doesn't miss n+1th point so that when we will export the trace, the file will have n+1th point.
Kind Regards,
deltat_proc:process(clk)
begin
if (clk='0') and (clk' event) then
deltat_rec <= delta_t;
end if;
end process deltat_proc;
    I think a more complete example will be needed to try this out and advise  you (that's partly the reason why I've not answered this so far). I don't have time to spend time putting together a complete example to investigate...
    If you can't share that here, please contact customer support.
