  3. Return a string from user-defined function in VerilogA
  • Views 17545
DimitarT
DimitarT over 6 years ago
I am trying to define a custom function (analog function) that takes a string input and returns a string;
analog function integer foo;
   input strin;
   output strout;
   string strin;
    string strout;
  begin
       strout = {strin,strin};
end
endfunction
string output_str;
analog begin
 @(initial_step)
      foo("bar", output_str);
end
This yields an error during similar to:
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file /…./…/Sim/… … /adexl/results/data/Interactive.33/sharedData/CDS/ahdl/input.ahdlSimDB/24626ad5616da27e0a69c18e90226eba.bias_autotrim.ahdlcmi/Linux-64//..//ahdlcmi.out for details. Contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
    ERROR (SFE-91): Cannot run the simulation because an AHDL compilation error occurred. Check the VACOMP error message above and correct the syntax error in the Verilog-A file. Next, rerun the simulation.
Investigating the ahdlcmi.out file, the first encountered error is:
aslDevAssignStringC(2, &stateDataStruct->input_str_144,(char*)stateDataStruct->input_str_152, funcModeParam);
In file included from test.c:24:0:
/mnt/ed/ct/lnx/rh/53/64/…/spectre/tools.lnx86/spectre/ahdlcmi/include/ahdlDevLibGlobal.h:2390:32: note: expected 'char *' but argument is of type 'long int *'
 ASL_FUNC_DECL_START extern int aslDevAssignStringC( int, char *, char *, struct ahdlFuncModeParam * );
I guess this is some intermediate compilation message (VerilogA->C), but I couldn’t get further investigating it.
Interestingly, removing the strout output parameter from the function and leaving only an input string works just fine.
What could be a possible solution to this issue?
Cheers,
Dimitar
    Hi Dimitar,
    This is a bug. In an older spectre version (when you could still disable the VerilogA compilation), the code does work - it's just the compilation that fails. I filed a change request (CCR 2203954) to get this fixed. If you want to track this yourself, you should contact customer support and request that a duplicate is filed so that it's then associated with you (this is better, as customer-filed issues get higher priority than internally filed issues).
