  3. Maestro: Use Simulation sweep variable in output equati...
  • Replies 8
  • Views 24029
Maestro: Use Simulation sweep variable in output equation
HoWei
HoWei over 6 years ago
this question was asked often in the forum (in different ways), but I did not yet find a definitive answer for this:
I am using Assembler to perform simulations.
I am doing a DC sweep on variable "Vgs". The variable is swept by the DC simulation from 0 to 1.0 - not via the tests DesignVariable.
The test DesignDariable is set to "0.99".
Now I want to use the swept variable in output equations via VAR("vgs") - but this gives me a constant of 0.99, and not the expected swept values.
Why is that and how can I access the swept variable ?
Of course I can do the sweep using the DesignVariable "vgs 0:0.1:1", but this creates 11 simulations, that take much longer.
The actual circuit is complex and I want to save simulation time.
I am using IC6.1.7.1400.500.
Please let me know what the best way is to access the sweep variable values.
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago
    I would guess that the xval function (with an arbitrary signal as argument) will do what you want.
  • HoWei
    HoWei over 6 years ago in reply to Frank Wiedmann
    Well, the variable is not a signal, its a variable that is used as a parameter in a schematic instance.
    But I'll give it a try ...
    Can you tell, how you are doing sweeps in Maestro ?
    Are you always sweeping via DesignVariables instead of AnalysisVariables ?
  • Frank Wiedmann
    Frank Wiedmann over 6 years ago in reply to HoWei
    The xval function gives you the x-axis value of the result, which I guess is what you want.
    Andrew Beckett over 6 years ago in reply to Frank Wiedmann
    As Frank said, it doesn't matter what you are sweeping or how you are sweeping - the xval function gives you the x-axis versus itself for any waveform. So if you use xval(VS("/blah")) it will give the sweep variable for the DC sweep.
    Whether you use a Design Variable sweep or a sweep in an analysis (presumably that's what you mean by "AnalysisVariables", a term I've never heard before) rather depends on precisely what you want to do - so I don't think it's something that can be generically answered.
  • HoWei
    HoWei over 6 years ago in reply to Andrew Beckett
    Guys - you once again made my day !
    Thats exactly what I was looking for !
    Thanks a lot  ;-)))
    ShawnLogan over 6 years ago in reply to HoWei
    Dear HoWei,
    Please allow me to add a comment/question and a possible suggestion....
    By any chance, do you have the Design variable "vgs" in your test defined as a Global variable (i.e., checked as a Global variable)?  If so, have you tried removing the check mark adjacent "vgs". With it unchecked as a Global variable, it seems as if Maestro will look in the test editor for its current value. With it checked, as you noted in your observation, the value will be fixed at 0.99.
    Just a thought,
    Shawn
  • HoWei
    HoWei over 6 years ago in reply to ShawnLogan
    Hi Shawn,
    nice idea - I tested it and what happens is:
    Once unchecked the Global "vgs" it enables the DesignVariable "vgs" and the behaviour isthe same as before - only 0.99 is available via VAR("/vgs") in the output
    On more question aside the problem: what does the checkbox next to the DesignVariable do ?
    If I check it or not, I do not see any difference.
    Andrew Beckett over 6 years ago in reply to HoWei
    The checkbox for design variables only makes sense if you have the global variable enabled.
    If you have the global variable unchecked, then the local (design variable) value is always used (and the checkbox is unnecessary and has no effect)
    If you have the global variable checked, then normally the local (design variable) value is not used (there's a strikethrough through the design variable); if you check the design variable you can then enable the design variable value for that specific test whilst leaving the other tests to use the global variable.
    I wouldn't have expected Shawn's suggestion to help in this case because the sweep is being done inside the analysis, and so the design/global value (which is what VAR() retrieves) is not what you want.
