  3. Including geometric variations in Montecarlo simulation...
  • Replies 9
  • Views 19897
Including geometric variations in Montecarlo simulation (ADEXL)
NorNand
NorNand over 6 years ago
Hello
I read a couple of papers in which the author performed a montecarlo based on geometric (dimention) variations of the elements in the circuit.  is there any setting in MC for that ?
If you like to have a look here are the papers
ieeexplore.ieee.org/.../4349224
link.springer.com/.../s10470-016-0874-2
Also in the first paper the author run the Montecarlo in over process corners (SS, FF...etc), why he should include these corners when it will already covered by the Montecarlo variation ?
Usually for me I run with MC two other corners that are supply voltage and temperature variation but never tried to include process corners with it nor having an idea about including geometric variation
Thank you very much
    ShawnLogan over 6 years ago +1
    Dear NorNand, NorNand said: Also in the first paper the author run the Montecarlo in over process corners (SS, FF...etc), why he should include these corners when it will already covered by the Montecarlo…
    Andrew Beckett over 6 years ago in reply to ShawnLogan +1
    I agree with Shawn - the first paper doesn't mention monte carlo, and I couldn't access the second paper as it requires a login that I don't have... Anyway, typically the monte carlo models provided…
    Andrew Beckett over 6 years ago in reply to NorNand +1
    No, you are not allowed to attach the PDF here. This would be in violation of the copyright holder and I would delete the PDF as the forum moderator if you did post it here (it's a bit of a giveaway since…
    Dear NorNand,
    I'm not sure if I am overlooking something, but the link to the "first paper" does not appear to discuss the subject of Montecarlo variation - at least I could not find it. The article is titled "An Ultra-Low-Voltage Ultra-Low-Power CMOS Miller OTA With Rail-to-Rail Input/Output Swing"
    In any case NorNand, an attempt to include geometric variation as well as process case variation appears to be redundant. Further, inclusion of both will likely lead to variations that are not realistic of the process. I've never had a foundry that lists the expected variation in geometries - that is the reason the foundry provides models for different process cases. I highly doubt a circuit designer can accurately assess the correlation between geometric variations for a given foundry. Hence, my thought it is best to utilize the foundry model cases as means of including expected process parameter variations.
    I always include process variation in Montecarlo simulations. Why? Typically, I am interested in the variation in such parameters as offset voltage, headroom, and duty cycle of a waveform. The magnitude of these variations correlates with the magnitude of the device threshold voltages. In a slow silicon process case, the threshold voltages will be larger than in a typical or fast process case. Duty cycle error can be highest in a mixed silicon process case (i.e., slow p, fast n). Hence, to estimate the maximum expected variation, performing a Montecarlo analysis with a slow silicon or mixed silicon process in addition to a typical or fast case will indicate the range in parameter variation.
    I hope I understood and answered the spirit of your question NorNand.
    Shawn
    Anyway, typically the monte carlo models provided by foundries are capturing the process-based random variation (die to die) and mismatch-based (which would probably be better called "local") variation. These are capturing the renaming random variation of the device, not the systematic variation caused by poor layout (e.g. lack of proximity, alignment or orientation). A design sensitive to the effects of this random variation per device is more likely to require good layout to match similar devices, but that's not strictly what you're measuring.
    Also, the model variation is not normally in terms of physical dimensions (nor are the process corners). I see no reason to try to vary those statistically as well (for a start, where are you getting the data about how they vary?). Some foundries do provide models which do local variation about a process corner, but many provide statistics models that vary across the entire process (and local mismatch variation too), and in that case it would make no sense to simulate over PVT corners. Over VT corners, yet, but not PVT.
    So the best thing is to consult the documentation for the specific PDK/models you're using. Understanding what the models are capturing is the best way to know how to use them.
  • NorNand
    NorNand over 6 years ago in reply to ShawnLogan
    Thank you Shawn for your nice infiormation,
    actuallly the first paper was not about montercalo itself, but the author run the MC for his design in the way I described,
    your feedback is very helpful
    thanks
  • NorNand
    NorNand over 6 years ago in reply to NorNand
    Dear Andrew,
    Thank you for your reply,
    Nothing I can add because you made it very clear,
    thank you once again
    Regards
  • NorNand
    I have noticed that I have done a mistake on the title of the first paper, it should be
    https://www.sciencedirect.com/science/article/pii/S0026269216302373
    Am I allowed to attach the paper pdf file here ?
    No, you are not allowed to attach the PDF here. This would be in violation of the copyright holder and I would delete the PDF as the forum moderator if you did post it here (it's a bit of a giveaway since they even charge for the PDF on the link you said; even if it was freely published I suspect they would not allow re-publishing elsewhere, and referencing their link would be enough).
  • Irenexox
    Irenexox over 5 years ago in reply to Andrew Beckett
    hi andrew,
    "These are capturing the renaming random variation of the device, not the systematic variation caused by poor layout (e.g. lack of proximity, alignment or orientation)."
    Do you mean i will get different monte carlo results with two layout: the first one have key device with common centriod layout and the second have no matching technique?
    Andrew Beckett over 5 years ago in reply to Irenexox
    No, if the design netlist is the same, you would see no difference. Monte Carlo knows nothing about the layout positioning, and what you are talking about is a systematic variation not a random variation - there's nothing to capture that, nor model it.
    Now of course, if you did a monte carlo mismatch simulation of two extracted netlists of the different layouts, you would likely see a difference - but that's more likely just to be because the random numbers are different caused by the differing parasitics and order of the devices in the netlists.
    Monte Carlo "mismatch" variation would likely tell you which devices in your design have more impact to the variation of the output measurements (particularly if you're using mismatch contribution analysis), but it is not going to tell you whether one layout arrangement is any better than another in terms of reducing systematic variation.
  • Irenexox
    Thanks a lot for your clarification.
