  3. error occurred when i save the schematic
  • Views 15429
jyoti kandpal
jyoti kandpal over 6 years ago
I'm getting the error when I'm trying to create schematic on Schematic editor. it shows an error like .*Error* hiCreateCyclicField: value must be contained within the list of choices".i m using virtuoso 6.1.5 version.
    Can you enter (in the CIW):
    _stacktrace=50
    and then do the same operation which triggers the error? Hopefully it will give a bit more information. If that doesn't work, try also:
    sstatus(errsetTrace t)
    The error is a low-level SKILL error related to the UI, and from that error alone it's not possible to identify the problem without more context (especially as you're using a version that is at least 6.5 years old).
