  3. virtuoso export stream option
  • Replies 7
  • Views 19581
skillEater
skillEater over 6 years ago
Hi
When I am trying to export gds from virtuoso.
The streamout form is not opening. I faced this issue for a couple of times now.
I tried reopening the virtuoso but is has not worked.
it is executing the command  pipoDisplay(transStreamOutForm) But its not opening.
please help me.
Ganesh Doddipatla.
    Hi Ganesh,
    It would help rather a lot if you said which version you're using. In current versions, it should be:
    pipoDisplay(transStreamOutNewForm)
  • skillEater
    skillEater over 6 years ago in reply to Andrew Beckett
    Thanks for the reply.
    your command has worked.
    My virtuoso version is ICADV12.3.But I exportedby going through File>Export>Stream.
    It is executing the old command.
    How to set to new.
    Please help me.
    Ganesh Doddipatla.
    Andrew Beckett over 6 years ago in reply to skillEater
    Most likely you have some old menus files lying around and you're not picking up the menus from the installation. Check using:
    cdswhich -all menus/ciw.menus
  • skillEater
    The command is not working andrew.
    You need to type this in a terminal window, not the CIW. Sorry, I didn't explicitly say that.
  • skillEater
    I know it.
    I typed it in terminal only.J
    sorry, I did not explained you properly.
    The result is cdswhich: Command not found.
    Ganesh doddipatla.
    You must have some wrapper script around virtuoso to start it rather than having the IC tools in your path. Instead type this in the CIW:
    ddGetStartupAll("menus/ciw.menus")
