  3. trouble enabling MPT coloring in IC18
  • Views 17413
Stevemc12
Stevemc12 over 6 years ago
I'm having trouble getting the MPT Coloring to work. I'm sure I'm just missing something simple.
I have run (mptActivate t) but in the Properties window for my rectangle the MPT section remains grayed out. I am using the same techlib, which includes colorMap, and same oalibs as other colleagues who can use the properties but were unfortunately unable to tell me how to fix mine. Are there other settings I need to enable?
  • rudyc
    rudyc over 6 years ago
    You may want to crosscheck the MPT settings by running the following command:
    mptReportCurrentSettings(geGetEditCellView())
    Then check that the v1 drawing is part of the Colorable LPP section
  • Stevemc12
    Stevemc12 over 6 years ago in reply to rudyc
    I'm not sure, but apparently not. Does this indicate that the Colorable section is empty?
    MPT flow report for scratch/g1mnand02ab3d36x5/oa
    @(#)$CDS: virtuoso version ICADVM18.1-64b 05/28/2019 19:28 (cpgbld01) $
    Dec 18 10:32:45 2019
    Technology file:
    Colorable layer(s):
    MPT constraintGroup: default
    Available MPT constraintGroup(s) in the tech file:
    virtuosoDefaultMPTSetup
    Colorable LPPs:
    Default Colors:
    none
    Coloring Methods:
    Session coloring method : colorSpacing
    Design coloring method : colorSpacing
    Main MPT cdsenv:
    Dynamic Coloring/Coloring Engine: t (mpt.coloringEngineEnabled)
    Default shape assignment: "asIs" (mpt.unclusteredShapeColor)
    ReColor read-only cellViews: nil (mpt.reColorReadOnlyCellView)
    Copy color(makeCell & flatten): nil (cdba.copyMPAttributes)
    Lock propagation: nil (mpt.propagateLocksToConnectedShapes)
    HCL creation during LockAll: "noHCL" (mpt.lockAllHCLPolicy)
    Policy for CELL:
    Instance Color Shifting: "none" (mpt.globalColorShiftingPolicy)
    Hierarchical Color Locking: "all" (mpt.enableHCLCreation)
    Policy for PCELL:
    Coloring: t (Opposite of mpt.dontColorPCells)
    Recoloring On Evaluation: nil (mpt.forcePcellRecolorOnEval)
    Instance Color Shifting: "cluster" (mpt.globalColorShiftingPolicyForPcells)
    Hierarchical Color Locking: "all" (mpt.enableHCLCreationOnPcells)
    Cdsenv with current value different than default:
    mpt coloringEngineEnabled boolean t (default: nil)
    mpt defaultColoringMethod cyclic "colorSpacing" (default: "connectedShapes")
    INFO: Report saved to 'mptFlow.rpt'
    t
  • rudyc
    rudyc over 6 years ago in reply to Stevemc12
    It looks like there's no colorable layer defined in the techFile which would explain why the color field is grayed out in the property editor.
    You can run the same command on the environment of your colleagues to see if the section is empty.
    Then you can compare the tech graphs (Tools -> Technology File Manager -> Graph) to detect a potential problem in the ITDB.
    The colorable layers are defined by the #Masks field in the techLayers section of the techFile.
    You can dump also the techFile(s) using Tools -> Technology File Manager -> Dump to confirm the mask number is set to 2 or above.
    techLayers(
    ;( LayerName     Layer# Abbreviation [#Masks] )
    ;User-Defined Layers:
    ( NWell                5         NW )
    ( v1                      10       V1                 2       )
  • Stevemc12
    My techfile has this for the techLayers
    ( v1 13 v1 3 )
    ( m2 14 m2 2 )
    The via1 layer does have 3 colors in our technology, and metal2 2 colors. Is there anything that needs to be done during the compilation of the text file into the TechLib?
