  3. Launching ADE L failed
  • Views 18693
Chofield
Chofield over 6 years ago
Hi, I am using IC617 to integrate simulator with Virtuoso.
I have following warnings and error happens when I am trying to launch ADE L from Schematic Editor window.
*Warning* hiCreatePulldownMenu: The menu must contain at least 1 entry
*Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
*WARNING* (DEBASE-102079): A SKILL error occured in function _sevDataTrigger
*WARNING* (DEBASE-102084): Data trigger for viewType adestate failed
Those errors happened during doing the CDB2OA conversion.
Could someone help me to solve those problems? Thank you very much!
There is another problem happens when I am trying to run the state tran. it is failed to open the state Tran becaue it uses the spetreVerilog simulator which is not supported by the current version of Virtuoso. Can anyone help me to solve this problem as well?
    I'm not sure why these errors would happen during cdb2oa conversion since this implies some SKILL code to create menus is being loaded. Debugging it in the forums is going to be almost impossible because any of us would need to see what you're doing.
    Similarly, I don't understand what you're expecting if trying to load a state for a simulator that no longer exists. It clearly cannot work...
    Please contact customer support.
  • Chofield
    Chofield over 6 years ago in reply to Andrew Beckett
    Thank you for reply.
    Best regards,
    Chofield.
    Andrew Beckett over 6 years ago in reply to Chofield
    No, because every PDK does things differently so I don't know how you have "set PDK environment", so can't say how to undo it.
    As I said, please contact customer support as this will almost certainly be best solved by having an application engineer look at your setup together with you.
