  3. How to sweep multiple params and save the specific param...
  • Views 16968
How to sweep multiple params and save the specific param selected from the circuit?
diffsland
diffsland over 6 years ago
first of all,  i am fresh here. and i am happy to be here.
recently, i am learning how to use ocn. and i met a question troubled me a lot.
simulator('spectre)  //  design(".../netlist")  //  resultDir(".../schematic")  //  modelfile('(".../saveop.scs" "") '(".../toplevel.scs" "top_tt"))
analysis('dc ?saveOppoint t ?dev "/V2" ?param "dc" ?start "0.3" ?stop "1.1" ?lin "200")
envOption('analysisOrder list("dc") )
temp(27)
run()
selectResult('dc)
ocnPrint(?output ".../xx.dat" ?numberNotation 'scientific getData("M0:gm"),....)
this is the code i am use to get param from circuit.
however, i have to sweep multiple params in circuit, and save the params from circuit as mentioned above.
i've tried "foreach, while" synax, and  failed. and i also read the ocnref together with ocn sample script in dfii.
unfortunately, i could not figure out how~~~
the param sweeping code i attached below:
analysis('dc ?saveOppoint t )
desVar ("a" 650m)
desVar("b" 300m)
temp(27)
paramAnalysis("a" ?values '(0.6 0.62 0.64)
paramAnalysis("b" ?values '(0.3 0.35)))
paramRun()
hope someone could help me~~thanks a lot!!!
    ShawnLogan over 6 years ago
    Dear diffsland ,
    I am sure others will warn you, so I will at least mention it, but the param() functionality is rarely used today in lieu of Assembler or Explorer. Nevertheless, I do occasionally use it and used it quite often in the past. I will also add that it is far less efficient than the job submittal processes in Assembler or Explorer.
    I have attached some sample ocean code that will retrieve data from a parametric analysis. In this case, it is computing the real and imaginary parts of an impedance. The param function sweeps a DC voltage over  a particular range and the code computes the real and imaginary impedances for each value of the voltage over that range. The sweep over the range is accomplished using a while() loop. A foreach() loop surrounds the code to run the data retrieval on three separate param() analyses in three different simulations. The results are written to a comma-separated variable file for each simulation directory. The function calls two procedures that I also attached - getWave() and find_netlist_param(). The former replaces the ocean getData() command and adds some error checking to make a failure to access a waveform more visible. The latter finds the process case that is used in the simulation. I hope the code is commented well enough for you to understand how to access results from a param() analysis. The three files are in the attached zip file.
    Shawn
    param_ocean_files.zip
  • diffsland
    diffsland over 6 years ago in reply to ShawnLogan
    thanks very much
    ShawnLogan over 6 years ago in reply to diffsland
    Dear diffsland,
    I just hope the code makes sense to you..good luck!
    Shawn
