  3. Transistors Operating Region check in Ocean Script
  • Views 16168
AtaV
AtaV over 6 years ago
I am trying to optimize my design using cadence ocean script to print a results on text file and then I am using Matlab for post processing this results and do iterations. The first criteria I have is to check whether the operating region of Transistor is in saturation or not "if(Region==2)". For 1-dimensional sweep I used to do it by writing "save MP:all" in text file and adding the path in stimulusFile and using using getData("MP:region" ?result "dc") to get transistor operating region.This method works very well in 1-dimensional sweep, however, I tried to use the same way for 2-dimensional sweep and it was not helpful. Does anybody know a way of checking transistors operating region in multi-dimensional sweep?
Ata
    Hi Ata,
    Why was it "not helpful"? You'd use the same mechanism to save the data, and the getData() function should still work if you've done further sweeps around the dc (it probably would help to know how you've performed the sweeps). The getData() would then return a family of waveforms (rather than just a single value (in the case of no sweep) or a waveform (in case of 1-dimensional sweep)). The ocnPrint function (for example) would print out all of those different family functions.
    So I think you'll need to describe in more detail precisely what you're doing (maybe with an example) so we can understand what you're doing wrong.
    By the way, nowadays you don't need to include a file to save operating point information - there's a menu Outputs->To be saved->Save Op Parameter (or something like that) in ADE. If that's not there, you're presumably using an old (unsupported) version of the IC tools.
    ShawnLogan over 6 years ago in reply to Andrew Beckett
    Dear AtaV,
    As Andrew noted, the question is how you are doing your "multi-dimensional sweep". If you are using the ParamTool, the manner of accessing the data will be different than if you are using ADE-XL or Assembler. As Andrew also noted, the use of the getData() function is still correct in a "multi-dimensional step". However, I believe the syntax used to access the particular sweep member will be different depending on the manner in which you are performing your sweep.
    Shawn
