  3. Import/exporting from cadence calculator
  • Views 3255
AtaV
AtaV over 6 years ago
Dear All,
Is there a way to export and import back the equations from cadence calculator or the list of ADE L outputs?
Thanks in advance
    You can use the Outputs->Export menu to export to a file (and then Outputs->Import to read them back):
    Or you could use the Outputs->Send to Expression Editor menu and then in the Expression Editor in the calculator, use these two icons to save or load the expressions:
    Note that for expressions in the calculator buffer, you could use the "expr +" icon to add into the expression editor and export individual expressions that way.
    So there are plenty of ways this can be done.
