  3. Using calcVal() function in ADE Explorer is possible?
  • Views 17055
Johanny Saenz
Johanny Saenz over 6 years ago
Hi all.
I would like to know if calVal() function is supported in ADE Explorer and if yes, how it can be possible?
Due ADE Explorer has an unique test bench, I have doubt of it.
    I think this would only make sense if you’re using it from the same test (or without the second argument).
  • Johanny Saenz
    Johanny Saenz over 6 years ago in reply to Andrew Beckett
    Hi Andrew.
    It is not possible to use calcVal() in ADE Explorer ( it's just possible to use in ADE Assembler). One better approach is use MDL Control File and passing the argument like
    alias measurement dc_trim {
        export int     trimed_word
        export real vref_initial
        run dc
        trimed_word=round(cross(sig=V(vout),thresh=0.5,n=1))
        vref_initial=V(vout)  @ 8
    alias measurement dc_final{
        export real vref_final
        trim_word_par=dc_trim->trimed_word
        run dc (param=temp, start=-40, stop=125)
        vref_final = V(vout) @ 25
    run dc_trim
    run dc_final
    Thanks!
