  3. How we can use the single VCVS file containing N waveforms...
  • Subscribers 128
  • Views 17108
How we can use the single VCVS file containing N waveforms for generating the N voltage waveform sources in ADE-XL ?
RFStuff
RFStuff over 5 years ago
Dear All,
I thought to create a new thread for this post instead of adding to an old but related thread.
We can save N voltage waveforms in a vcvs file by using the thread community.cadence.com/.../1285946
But, how we can use the single VCVS file for generating the N voltage waveforms  in ADE-XL ?
Kind Regards
    It's not really ADE XL that is the issue here - the spectre vsource does not provide a means to specify which column to read from the file, so it only supports one time and one voltage column.
    The only alternative would be to write a Verilog A model which could read the data in the file and then you would specify the column to use.
    So in general, there's not really support to do this.
  • RFStuff
    RFStuff over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    Can it work like vsource functionally ? How it will know the time instant of when the simulator need the time point of the waveform. The simulator uses dynamic time steps
    Andrew Beckett over 5 years ago in reply to RFStuff
    You'd need to read the file and store the points (probably) and then use @(timer(...)) to schedule a time point at the point in the waveform file. I don't have any code that does this for reading a file, but a similar approach is used in How to specify more than one region of time where strobeperiod is enabled in a transient analysis (this has an array used to specify start/stop times for strobing, and then needs to strobe at specific timepoints within those windows). You might be able to borrow some ideas from that.
    With a PWL source, normally it only forces the timepoints (i.e. adds breakpoints) if there are fewer than 20 points - otherwise it assumes the waveform is "smooth" (allbrkpts is used to override this behaviour) - so you may or may not need to force timepoints depending on how smooth the waveforms are.
