  3. Define libraries as read-only
  • Subscribers 133
  • Views 19651
HoWei
HoWei over 6 years ago
is there a way in cds.lib to define libraries as "read-only" ?
I do have libs defined in cds.lib from another project, which I want to have read-only.
I do not want to set permissions via the Linux system, because there is a revision control system in between.
Instead I am looking for a way to write-lock (read-only) libs with Cadence settings
    You can't do this in the cds.lib  but with a bit of SKILL code you can create a trigger that a achieves the same thing. This code below (keep the .ils suffix because it relies on SKILL++ lexical scoping) can do this - the comments at the top explain how to use this:
    /* abReadOnlyLibs.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 20, 2020
    Modified
    By
    Registers a list of libraries to be readonly in this session:
    abReadOnlyLibs(list("mylib" "yourlib"))
    If you need to make them editable again, you can do:
    abReadOnlyLibs(nil ?reset t)
    or
    abReadOnlyLibs(list("newlib") ?reset t)
    SCCS Info: @(#) abReadOnlyLibs.ils 01/20/20.11:37:49 1.1
    let((readOnlyLibs)
        *                abReadOnlyLibs(listOfLibs @key reset)                *
        * Register a list of libraries to be readonly. If ?reset t is passed, *
        *       it forgets any previously registered readonly libraries       *
        globalProc(abReadOnlyLibs(listOfLibs @key reset)
            when(reset || !readOnlyLibs
                readOnlyLibs=makeTable('readOnlyLibs t)
            foreach(libName listOfLibs
                readOnlyLibs[libName]=nil
            ddRegTrigger("PreAutoCheckOut" 'abReadOnlyLibsPreAutoCheckOut 1)
            t
        *      abReadOnlyLibsPreAutoCheckOut(@optional objList _isBatch)       *
        * Trigger which does the work to check whether you are allowed to edit *
        *                          the object or not                           *
        globalProc(abReadOnlyLibsPreAutoCheckOut(@optional objList _isBatch)
            foreach(mapcar obj objList
                readOnlyLibs[obj->lib->name]
  • HoWei
    HoWei over 6 years ago in reply to Andrew Beckett
    Too bad that there is no"non-scripting" way.
    I will try when I find some time.
    Andrew Beckett over 6 years ago in reply to HoWei
    There might be a way with your revision control system too. The code above is not very complicated, and certainly a reasonable approach for something a little non-standard. This is one of the reasons why we have a powerful programming capability with SKILL in Virtuoso!
  • HoWei
    Yes, that is another option, but unfortunately (as we have setup our revision control environment), we can only lock complete "referenced project", but not single libs within these "referenced projects". Of course there are also ways that include scripting (pre-chkout-triggers and so on) to achieve it - but its not very handy for designers.
    There are option and we have to find the way that matches best to our environment.
