  3. How to know the END of a Spectre Simulation fired in the...
  • Views 15738
How to know the END of a Spectre Simulation fired in the Linux terminal.
RFStuff
RFStuff over 6 years ago
Dear All,
I fired a Spectre Simulation in Linux terminal. (spectre filname.scs).
It ran successfully, Is there any way (like some command) by which  we can detect the end of the successful or un-successful simulation run ?
Kind Regards,
    Well, the end is easy - you wait until the job has finished - the process exits when complete. Whether it was successful or not depends on what type of "success" you are talking about. You can use the exit status ($status or $? depending on the shell you're using) - anything other than 0 means a severe error occurred. For some things, e.g. a convergence failure during an analysis, it's a bit trickier. You could use:
    spectre +logstatus input.scs
    and then in the input.raw directory (or wherever you have the -raw specified), there will be a file called "logStatus" which records each analysis that starts and how it ends. For example:
    8:57:29 AM, Mon Jan 27, 2020 ac START
    8:57:29 AM, Mon Jan 27, 2020 ac FAIL
    8:57:29 AM, Mon Jan 27, 2020 elements START
    8:57:29 AM, Mon Jan 27, 2020 elements PASS
    That's a bit simpler to parse than the normal spectre log file.
  • RFStuff
    RFStuff over 6 years ago in reply to Andrew Beckett
    Thanks a lot !
